Example Code
NI 9203 Gain Accuracy Adjustment with DAQmx
Products and Environment
    Software
  • LabVIEW
    Driver
  • NI DAQmx
    Other
  • NI-9203
Code and Documents
Description
Overview
This example looks at using an external calibrator to adjust the gain on your NI 9203.
Description
This program refers to step 3 of the 9203 Calibration Procedure Manual. It is highly recommended that you review this manual before using this code snippet.
Requirements
Software
  • LabVIEW 2013 or compatible
  • DAQmx 9.8 or compatible
Hardware
  • NI 9203
  • Most cDAQ Chassis (ie.9188, 9174)
  1. Open LabVIEW 2013
  2. Press CTRL + E to view the block diagram.
  3. Select your 9203 as the source on the initialize block
  4. Select the 9203 on the Adjust Calibration Gain block
Additional Information or References
