Overview
This example shows how to do simple analog input using a 9215 module.
Description
FPGA Top Level Block Diagram
Real Time Host VI
Requirements
LabVIEW 2009 "or compatible"
LabVIEW FPGA 2009 "or compatible"
NI RIO 3.3 "or compatbile"
1.) Download the attached zip file and extract it into a single folder
2.) Open the LabVIEW project, use the FPGA VI and host VI with your cRIO.
Note: If you change the hardware target at all you will need to recompile the FPGA VI.
3.) Run the real time host vi
Additional Information or References
This example only uses simple timing, and the data transfer from the FPGA will likely lose some data.
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
