Example Code
NI-DAQmx Channel List String to Array of Channels
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Description
Overview
This VI shows how to use this handy converter to create a dummy task and extract the channel list in array format.
Description
You may find a need to extract the individual channels from a task that was made by using some sort of short-hand syntax. (What is the Syntax for Physical Channel Strings in DAQmx?)
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
1. Open VI
2.Select physical channel
3.Run the VI.
Peter Flores
