Example Code
NI-DMM Switch Express to Acquire Data
Products and Environment
    Hardware
  • Modular Instrumentation
    Software
  • LabVIEW
Code and Documents
Overview
This example is a great tool to quickly acquire data from your NI-DMM.
Description
Use this example code to easily acquire and save data from you NI-DMM hardware. You can also view the data in a waveform graph and in an array while the program is running.
Requirements
Software
LabVIEW 2012(or compatible)
NI-DMM driver which is compatible with your hardware and version of LabVIEW
Hardware
NI-DMM Device
  1. Open the example VI and configure the NI-DMM Switch Express VI to acquire data from your hardware
  2. Configure the Write to Measurement VI to save the file in your desired location and format
Additional Information or References
