Overview
This application example performs spectral RF measurements using a compatible NI-RFmx device.
Description
This example provides an interactive demo panel that allows the user to make various RF measurements simply by navigating to the desired measurement tab.
Each measurement tab provides allows the user to interactively configure the measurement settings and obtain the results. The following measurements are supported:
The user can combine several measurements into a "composite measurement" (processing is done on the same set of IQ samples ) by selecting "Composite?" checkbox at bottom left corner of each measurement tab. Once two or more measurements are marked as "composite", the "Composite Measurements Enabled?" LED (bottom right) will light up. Hovering the mouse over the "Composite Measurements Enabled?" LED will show the list of measurements being currently performed.
Instructions
1. Configure RF hardware settings (HW Resource Name, carrier frequency, refernce level, etc.)
2. Run this VI.
2. Use tabs to select and configure different RF measurements.
3. Use interactive controls at the bottom of the front panel to control acquisition.
Requirements
Software
Hardware
Any NI Signal Analyzer hardware compatible with NI-RFmx.
Additional Images
Figure 1. NI-RFmx SpecAn - Application Example Front Panel (WLAN spectrum measurement is displayed)
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
