Overview
 Demonstrates how to synchronize an analog acquisition task using NI Scope with an Analog Output task using NI DAQmx on a PXI system.
 Description
 This example shows how to synchronize an analog acquisition task using NI Scope with an Analog Output task using NI DAQmx on a PXI system.
The master task is the analog input which exports a Reference Trigger Signal on the PXI TTL 1 line. The slave task, the Analog Output, is configured with a Digital Trigger on the PXI TTL 1 line, so these two tasks become synchronized because they share the same trigger signal (PXI TTL 1 line).
Requirements
Software:
Additional Information or References
 VI Snippet
I didn't see an attachment, did you forget to add it, or did the system drop the link? Either way, please reattach. Thanks!
Ops I forgot to attach it...I just added right now.
Could you add bigger, seperate pictures of the FP and BD so we can see all of the nodes?
Done, it shoudl be fine now...Happy Easter!!!
