Overview
This VI will make an explicit path connection from one column to another in multiple NI SwitchBlock devices using NI-DAQmx.
Description
- Resets a switch device and sets its topology to the one you specify in Topology Name.
- Creates an array of row names and an array of analog bus names for your specific device.
- Allows the sharing of your analog bus over multiple devices.
- Makes multiple connections from one column to another as specified in the connection list on the front panel, and waits for the switch to finish closing.
- Handles any errors that have occurred.
Requirements
Software
- LabVIEW 2012 (or compatible)
- NI-DAQmx 9.3.5
Hardware
- Select your NI SwitchBlock device name, and ‘Configured Topology’
- Select the list of connections that you would want to make in the Connection List
- Repeat this for both your NI SwitchBlock devices
- Run the VI and the connections will be made as specified in your list of connections
Additional Information or References
VI Snippet
Frank,
Software Group Manager
