Example Code
NI System Configuration: Show All Hardware
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Displays all hardware and certain properties of that hardware on the specified target.
Description
This example uses NI System Configuration to show all hardware connected to a target. It displays the Alias/Resource Name, the Product Name and the Serial Number of each device. It can also be configured to display all network devices as well..
Requirements
  • LabVIEW 2012 (or compatible)
  1. Choose target
  2. Run VI
Additional Information or References
VI Block Diagram
Kaitlin N.
Comments
Pierro26
Member
Member
on
Thanks very usefull for beginners
Scott_Campbell
Member
Member
on
when I run this it does not return the info on c series module in chassis, is there any way to expand this to return module in chassis,
JoshuaP
Active Participant
Active Participant
on
Currently, the NI System Configuration API does not support discovery of cRIO modules, however it will work with cDAQ.
This has been a common request, however there are some technical limitations with how the FPGA interacts with the modules that makes it complex to add.
This is something that NI is actively working on, so hopefully it will be supported in a future release.
Oli_Wachno
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
Is there any chance to retrieve the data that MAX shows at "Port Description"?
I'm trying to use this string to identfy special hardware showing up as virtual COM port.
I have tried different properties but haven't succeeded yet.
