Overview
The example demonstrates how to automatically segment a file created using the Embedded Data Logger custom device,
you can use a model created in LabVIEW.
Description:
Steps to implement or execute code
To implement this example:
To execute this example:
Note: This model assumes that the Log Trigger channel is always true (= 1). Modifications will need to be made if the Log Trigger channel varies during deployment.
To adapt this for Rising Edge rather than Falling Edge, you can switch the Not function appropriately in Segment File Falling Edge.vi and then recompile the model. For more information on creating a model from LabVIEW, please see the white paper on this topic.
Installation
Requirements
Software
LabVIEW 2012 or compatible
NI VeriStand
Hardware
