Example Code
NI Week 2014 CPS: Data Viewer Control Demo
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Allows a specified control to be clicked and dragged over any graph to view the data underneath.
Description
      This example is the generalized version of a UI Element demonstrated at the 2014 NI Week Cyber Physical Pavilion. Everything this code does is a Native LabVIEW implementation. No external code is called.
By specifying a control by its Reference to the Data Viewer Main VI it is able to be clicked and dragged over any graph which has been moved to the back. Everything is done automatically. All that needs to be done is connect the required terminals of the Data Viewer Main VI. The center of the control specifies the location on the graph and controls a specific cursor which is automatically created.
The data specified by the cursor is read and either sent to the Control itself or sent into a Queue which can be used elsewhere in your application.
Requirements
Software:
  1. LabVIEW 2013
  1. Extract the Zip file.
  2. Open the Data Viewer Project.
  3. Open and Run Data Viewer Demo.
  4. Follow the directions for the Demo.
  5. Use the Data Viewer Demo VI as a guide when creating your own implementations.
Additional Information or References
NI Snippet
Alex D
Systems Engineer
Academic Research
