Overview
Dotnet implementation of command line interface to NVIDIA's system management (nvsmi.exe).
Nice to have if using NVIDIA graphics and CUDA powered applications.
Supported video adapters:
Check for details with NVIDIA documentation
Description
"DOTNET - NVIDIA - Get NVSMI Location.vi" - registry check for NVIDIA path, check for 32/64 bit flag. nvidia-smi.exe - 64-bit app.
"DOTNET - NVIDIA - List Devices.vi" - lists available adapters
"DOTNET - NVIDIA - Status.vi" - query to system managment
Requirements to Run
Software
Hardware
1. Compatible NVIDIA adapter
-Artur
Update 10/07/2016:
For 64-bit LabVIEW only!
NVIDIA - NVML - DLL (64-bit).zip - > Access to NVIDIA over DLL calls.
Missing file added to zip. Snapshot moved to document body, web editor wasn't working properly then and still doesn't let you insert images without wiping the text out... -Artur
