This FPGA IP example includes a host VI to demonstrate how to use and call the function. The FPGA IP allows you to determine what kind of noise you'd like to add to the sinewave - Gaussian or White Noise. These generators were built from the native LabVIEW FPGA generators.
Other requirements:
This example was created with an R Series in mind - using the emulator but can probably be applied to several different RIO targets.
