Overview
This VI uses a feedback node to hold the refence to a notifier. For demonstration purposes, this notifier uses a boolean as its data type. For other uses, change the data type to suit your application.
Description
Use this VI throughout your application to access your notifier. Because this VI uses a feedback node to hold the reference to the user notifaction, this VI is global, meaning it can be used anywhere in your application instance.
Requirements
Software
LabVIEW 2013 SP1 or newer.
Hardware
N/A
I do something similar. Except I go the full Action Engine route. I have an enum to state what to do with the reference. Options include Create, Close, Get Reference, and Send Command. Yep, I put the sending of the notification inside of the VI. Whoever wants to read a notifier can get the reference still and then wait for the notification.
I handle my queues the exact same way. It works very well for queues since only one place should be reading anyways (where you create the queue). So then anybody (in the project) can send the commands just by calling the Action Engine.
