Example Code
Number to Boolean String in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example converts a Number to Boolean/Binary String
Description
The LabVIEW String/Number Conversion Palette contains many functions to convert a number to a Decimal, Hex, Octal, Fractional, Exponential and Engineering Strings.  However there is one missing: The Number to Boolean/Binary String.  This can be replicated very easily with the attached code.
Requirements
LabVIEW Base Development System 2012 or compatible
  1. Enter the Number to be converted to Boolean string
  2. Enter the Minimum width, If width is larger than needed, zeros are added on the left. If width is inadequate, decimal integer string is as large as necessary.
  3. Run the VI
Additional Information or References
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Comments
Knight of NI
Knight of NI
on
See here for a simplified version.
David_L
Active Participant
Active Participant
on
Wow I did not know that function existed.  I changed the example to be much simpler.  Thanks for the help!
