Example Code
Obtain XML from a Webpage and Parse in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example searches an XML webpage and extracts the expression instances found
Description
Many websites have XML output that you can use to read data from. This code takes advantage of the HTTP Toolkit (installed with LabVIEW Professional) and the XML Parsing VIs.
Requirements
LabVIEW Professional Development System 2012 or compatible
1- Enter the webpage URL
2- Enter the XPath search expression
3- Run the XML_Webpage.vi
 Additional Information or References
The XML_Webpage.vi uses a modified Query XML Document for a Single Node.vi from the NI LabVIEW Example Finder. The Query XML Document for a Single Node.vi was modified so that its inputs and outputs were connected to the connector pane.
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Joshua B.
Comments
stubon
Member
Member
on
Is there a way to send a query to a website?
I am interested in returning information about a barcode I have read in.
There are several databases online where you can type in the barcode and get information back
e.g. http://gepir.gs1.org/V31/xx/gtin.aspx?Lang=en-US
I would like to send a query with the barcode and read back the information
Any ideas if this is possible?
DiscoBall
NI Employee (retired)
on
Howdy! You may be able to work with the HTTP Client: http://decibel.ni.com/content/docs/DOC-6252. An http POST to send and GET to receive. I hope that helps!
Joshua B.
