Overview
On/Off Relay Controller Program
Description
The program is setup for 4 analog input channels, 4 analog output channels. The program reads the AI in a loop controlled by the Wait function (software timed data acquisition). The analog data is then passed to the On-Off Control function, which turns on or off the relay based on the input set points and dead band. The Wait function constant is in ms, and can be changed based the need speed of control. On a Windows computer, the max loop speed is 10-100 Hz, depending on system hardware. This example could be modified to use PID control instead of On/Off control.
Requirements
Software:
Additional Information or References
VI Block Diagram
