Overview: This VI demonstrates how to only have a single 'branch' to be expanded at a time.
Description:
When using tree controls, it is sometimes desirable to only see a single 'branch' or 'thread' of that tree at a time. By default, if you expand a branch in a tree control, it remains expanded until you close it. This VI demonstrates how to only have a single 'branch' to be expanded at a time. So, if you had one branch expanded and expanded a seperate branch, this VI programmatically closes all other branches.
Requirements: LabVIEW 2012 (or compatible). Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI.
2. Expand the different branches of the 'Controlled Tree Control'.
3. Notice that if you expand a separate branch, the previously open branch closes.
4. Expand the different branches of the 'Default Tree Control'.
5. Notice that expanding one branch has no effect on other branches.
Additional Information or References:
