Example Code
Open a Project via an Executable using LabVIEW and ActiveX
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to load a project and open it programmatically.
Description
If you're looking to create an executable that opens a project on the computer it's running on, you won't
be able to access the LabVIEW application from the executable because it's running on the LabVIEW Run-Time Engine. To
overcome this, you'll need to use ActiveX to call into LabVIEW.exe to access the project files on the computer that the
executable is running on.
Requirements
LabVIEW 2012 (or compatible)
Steps to Reproduce
1. Select the project path and insert it in the "Project Path" string.
2. Run the VI.
Additional Information or References
