Example Code
Output Keyboard Symbols Using "Acquire Input Data.vi"
Code and Documents
Overview
This example is used to demonstrate how to translate the default output of the Acquire Input Data.vi to symbols for multiple keystrokes.
Description
For example: for the keystroke Shift + 8, the output of Acquire Input Data.vi is an array with elements (8, LSHIFT) if the left shift key was held or (8, RSHIFT) if the right shift key was held.This VI translates this data into a meaningful symbol - for example, pressing Shift + 8 results in the asterisk character *.An LED on the front panel indicates that multiple keystrokes have been translated. This example handles the following cases: A-Z, 0-9, !@#$%^&*(). That being said, it can be easily expanded to handle additional symbols.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attachment to your computer
  2. Open the VI "Acquire Input Data Multiple Keys 2012 NIVerified.vi"
  3. Run the VI
Additional Information or References
VI Snippet
