Example Code
Output Noise (White/Poisson/Binomial) using DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview:
The example is to demonstrate how to generate various kind of noise in the Analog Output pin
Description:
Using the Binomial Noise Waveform and DAQmx, we could access the Analog Output of the hardware and set it with the user-defined parameters of the noise. The selection of the noise is decided by using the case structure.
Steps to Implement or Execute Code:
To implement this example:
  1. Define the Input Physical Channel
  2. Set the value of the parameters as needed, including the tabbed options of the noise parameters
  3. Run the VI
  4. (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
  1. Install the required software.
  2. Connect the DAQ hardware that supports the AO features
  3. Confirm the connection with the MAX with TestPanel
  4. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Output Module
Comments
felix.t
Member
Member
on
This vi does not work.
HunterSeeker
Member Member
Member
on
This VI needs to be configured to work with a DAQmx device. What hardware are you using with it?
