Overview
This example demonstrates how to output a constant and specific analog voltage level which can be modified during runtime.
Description
This example outputs a constant analog signal continuously out of an analog output channel on a NI DAQ card. This VI uses a gauge control on the front panel to change the analog output voltage during runtime. This example will continue to run until the user decides to stop the VI.
Requirements
Software
Hardware
Additional Information and References
Block Diagram
Hi matt,
Here i need to control a electro hydraulic valve for load test the maximum load range is 200kN and output signal is 10V i need to give a command in terms of mV or in terms of kN/sec and also i need a three seperate control switch to start the loading pause at certain value and to reset the value for loading. Can you provide some ideas for this
Thanks in advance,
Dineshmeena
