Overview
Use this example to output a constant analog voltage, to one or more channels of a DAQ device, continuously.
Description
This example demonstrates how to continuously re-generate analog output data, of constant values, from a buffer in your computer's memory.
Refer to your device documentation for pinouts and hardware capabilities.
Note: this example is written so that when the VI is stopped, the output pins are reset to zero voltage.
Requirements
Software
Hardware
Additional Information or References
