Overview
This example demonstrates how to output a DC signal using the Analog Output of a Dynamic Signal Acquisition (DSA) device.
Description
NI DSA hardware is made specifically to input and output fast changing signals with a concentration on accuracy in the frequency domain and a great Signal to Noise Ratio. However, there might be a time when you need to use the AO on your DSA card to output a DC voltage. You will find this is a little more difficult than with a lower-cost board because the DSA doesn't allow you to simply update a voltage. This example shows you how to output a DC Voltage with your DSA card.
Requirements
Software
Hardware
Additional Information or References
Front Panel
Block Diagram
