Example Code
Overlays from IMAQ Match Pattern "Matches" Output
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to find patterns in and IMAQ Image and overlay the found matches in the image.
Description
If you are writing a pattern matching algorithm from scratch, you'll notice that you are provided a Matches array output from the IMAQ Match Pattern VI. The pattern matching VIs do not supply an overlay automatically to show you the location of each match. This example shows you how to modify the Matches output into overlay data such that you can place a bounding box of a desired color around each found pattern.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
--Michelle
