Example Code
Parse Web Page Title using LabVIEW
Code and Documents
Overview
This example VI read the HTML code from a webpage and parse its title.
Description
You can use This VI to obtain webpage title from the address an to see the HTML code. The HTML code is read using Datasocket API and after that it is converted to string. Then the VI searches the web page title using string function.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI
  2. Insert the website address
  3. Run the VI
  4. Title shows the webpage title
  5. A boolean indicator shows if an HTML timeout is
    occured
Additional Information or References
VI Block Diagram
 Parse Web Title LV2012 NI verified.pngParse Web Title LV2012 NI verified.png
*This document has been updated to meet the current required format for the NI Code Exchange.**
John Passiak
