Overview
Parsing the Nth and its respective multiple rows of a 2D Array.
Description
In this piece of code, a 2D numeric array is parsed by removing the Nth element and its multiples in the array. For example, if the parsing number is 4, the VI will remove the 1st, 4th after it, and so on until it reaches the end of the array.
Requirements
LabVIEW 2012 (or compatible)
1. Select the parsing number.
2. Run the VI.
Additional Information or References
