The TestStand Application Manager supports processing custom command line arguments through the ProcessUserCommandLineArguments event. This can prove useful when automating test execution from a CI server.
This example is similar to the LabWindows/CVI Basic User Interface, but has been modified to accept the following command line arguments:
| Option | Purpose |
| /SimulateFailure <failures> | When used with the included example sequence file, this suppresses the simulation dialog and instead simulate failures as specified. This argument accepts the following parameters:
This example demonstrates the following concepts:
static void DisplayError(int errorCode)
if (errorCode < 0)
printf("Error: %d %s",errorCode,errMsg);
TSUI_ApplicationMgrSetExitCode (gMainWindow.applicationMgr, NULL, errorCode);
tsErrChk( TSUI_ApplicationMgrAddCommandLineArgumentsHelp (gMainWindow.applicationMgr, &errorInfo, "[/SimulateFailure <failures>]", "<failures>: components to fail separated by spaces.\nvalid parameters are: Keyboard, Video, Power, CPU, ROM, & RAM", ""));
HRESULT CVICALLBACK ApplicationMgr_OnUserMessage (CAObjHandle caServerObjHandle, void *caCallbackData, TSUIObj_UIMessage uiMsg)
int error = 0;
LPUNKNOWN tempPropObject = 0;
CAObjHandle SeqContext = 0;
enum TSEnum_UIMessageCodes msgEvent;
tsErrChk( TS_UIMessageGetEvent (uiMsg, &errorInfo, &msgEvent));
tsErrChk( TS_UIMessageGetActiveXData (uiMsg, &errorInfo, &tempPropObject));
CA_CreateObjHandleFromInterface (tempPropObject, &IID_IUnknown, 0, LOCALE_NEUTRAL, 0, 0, &SeqContext);
if (msgEvent == TS_UIMsg_UserMessageBase +1)
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.UiMsgHandled", 0, VTRUE));
tsErrChk( TS_PropertySetValNumber ( SeqContext, &errorInfo, "Locals.KeyboardValue", 0, fails.Keyboard));
tsErrChk( TS_PropertySetValNumber ( SeqContext, &errorInfo, "Locals.VideoValue", 0, fails.Video));
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.PowerFail", 0, fails.Power));
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.CPUFail", 0, fails.CPU));
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.ROMFail", 0, fails.ROM));
tsErrChk( TS_PropertySetValBoolean ( SeqContext, &errorInfo, "Locals.RAMFail", 0, fails.RAM));
Error:
CA_DiscardObjHandle(SeqContext);
DisplayError(error);
return error < 0 ? E_FAIL : S_OK;
Note: By default, TestStand shows dialogs under certain conditions. This can cause hangs when automating sequence execution without user input, such as when ran from a CI Server. In order to prevent popups that require user input, configure the following options:
TestStand 2014 SP1 or later
LabWindows/CVI 2015 or later
TestExec /?
TestExec /runEntryPoint "Single Pass" "<ExampleDir>\TestSequence\Computer Motherboard Test Sequence.seq" /SimulateFailure Keyboard Video RAM /quit
TestStand Help: ProcessUserCommandLineArguments Event
TestStand Help: Configuring Sequence Editor and User Interface Startup Options
