Developed by Robert Emin
Phidgets Inc. distributes the 3503_0 - i-Snail-VC-100 100Amp Current Sensor which connects to a number of USB data acquisition devices provided by Phidgets Inc. In this case it is the 1011_0 - PhidgetInterfaceKit 2/2/2 dongle. Phidgets Inc. provides the DLL for Labview and over 100 functions and Vi's for Labview. This makes Phidgets a low cost high result choice for current, power, voltage, distance, range, pressure, force, touch, motion, envioromental with a wide selection of data acquisition devices. The formula for calculating the current is: AC Amps (RMS) = SensorValue/10
Product Specifications
Sensor Properties
Sensor Type Current (AC Through-Hole)
Sensor Output Type Non-Ratiometric
Input Current Min 0 A
Input Current Max 100 A
Current Measurement Resolution 100 mA
Measurement Error Max 0.5 %
Electrical Properties
Output Voltage Min 0 V DC
Output Voltage Max 5 V DC
Isolation Voltage (AC) 2.5 kV AC
Physical Properties
Material UL94V-0 ABS Plastic
Wire Window Size 13.7 mm
Operating Temperature Min -40 °C
Operating Temperature Max 50 °C
1011_0 - PhidgetInterfaceKit 2/2/2 Dongle Product Specifications
Board
USB Voltage Min 4.6 V DC
USB Voltage Max 5.5 V DC
Current Consumption Min 20 mA
Current Consumption Max 500 mA
Available External Current 480 mA
USB Speed Full Speed
Operating Temperature Min 0 °C
Operating Temperature Max 70 °C
Analog Inputs
Number of Analog Inputs 2
Analog Input Resolution 10 bit
Input Impedance 900 kΩ
Analog Input Voltage Min 0 V DC
Analog Input Voltage Max 5 V DC
5V Reference Error Max 0.5 %
Analog Input Update Rate Min 1 samples/s
Analog Input Update Rate Max 1000 samples/s
Analog Input Update Rate Max (WebService) 62.5 samples/s
Digital Inputs
Number of Digital Inputs 2
Pull-up Resistance 15 kΩ
Low Voltage Max (True) 800 mV DC
High Voltage Min (False) 2.1 V DC
Digital Input Voltage Max ± 15 V DC
Digital Input Update Rate 125 samples/s
Trigger Length Min 3 ms
Digital Outputs
Number of Digital Outputs 2
Series Resistance 300 Ω
Digital Output Current Max 16 mA
Digital Output Voltage Min 0 V DC
Digital Output Voltage Max 5 V DC
Front End User Interface
Block Diagram
Functions provided by Phidgets Inc. As can be observed, there is many more and a good variety.
This is the dongle hooked up to the front USB of a computer.
The current sensor. Very durable and tough.
can you please send a link from where the phidgets for labview setup
