Example Code
Phone Number Trick using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI performs an interesting algebra calculation ‘Phone Number Trick’.
Description
This is a fun example for algebra students and experienced math enthusiasts alike. When you enter the first three digits of your phone number, adding, subtracting, multiplying and dividing by various numbers (including the rest of your phone number) will eventually reveal the full number!
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Open the VI " Phone Number Trick 2012 NIVerified.vi"
  2. Run the program
  3. Enter the first three digits of your phone number (not the area code) in the first box
  4. Follow the math and enter the last four digits of your phone number where asked
  5. When you are finished, click the "Calculate My Number" button at the bottom to reveal your phone number!
  6. The math behind the trick is also explained at the bottom of the VI. Have fun, and keep math-ing!
Additional Information or References
VI Front Panel
VI Block Diagram
Will Hilzinger | Switch Product Support Engineer | National Instruments
