Example Code
Piano View - a (very) Little virtual piano made in LabView
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example makes a (very) little virtual piano in LabVIEW.
Description
The virtual piano allows the user to generate the sounds of each key by pressing the on screen keys, over many octaves either. Its volume and octave can be controled and it can display the sound signal waveform.
Requirements
  • LabVIEW 2012 (or compatible)
Steps to Implement or Execute Cod
  1. Open Piano 2012.vi an run this VI
  2. Play the piano by clicking on the key.
  3. Change the Volume and Octave can control the volume and octave of the piano.\
  4. The  Graph will show the sound waveform.
Additional Information or References
VI Snippet
The attached PianoView.rar provides an installer, it needs LabVIEW Run-Time Engine 2010 or compatible.
The attached Piano View 2012 NIVerified.zip just provides LabVIEW VIs, run the VIs can accomplish the same function. If you want to create an installer or an application(EXE), you can add the VIs to a project and create them.
Ing. Marcelo A. Valdéz
® MP: 155810/3707
☎ +549 (0351) 4733911
✉ mvaldez@arnet.com.ar
✔ http://dobaembedded.com.ar
Contact Me
Comments
alieas
Member
Member
on
I cant open this VI.... how to open this? i installed Labview 10 in my PC....
marxxelo
Member
Member
on
Hi!
Just unrar the archive to a temporary folder and run the "setup.exe" installer. Once the setup is completed,  PianoView will run automatically.
Try changing the waveform ("Forma de Onda" control) and the octave (from -3 to +4). The "Hastalavista Babe" control exits the program.
To explore and modify the source code, just go to "Pianoview distribution" subfolder. There, you can find the "pianito.vi", the "octava.ctl" control and the application icon.
Happy halloween!
Marcelo.
® MP: 155810/3707
Contact Me
Alex.T
Active Participant
Active Participant
on
This is brilliant! It looks great and the way that you have it swap keys on another press is fantastic.
Really, really well done!
Alex Thomas, University of Manchester School of EEE LabVIEW Ambassador (CLAD)
