Example Code
Picking a Specific Number of Waveform Peaks
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to find the largest peaks in a waveform.
Description
LabVIEW peak detector VIs provide peaks based on a threshold, but they don't provide the option to find a specific number of peaks. This VI lets users only look at a chosen number of the largest peaks in the waveform.
Requirements
1. LabVIEW Base Development System (or compatible)
1. Choose the number of peaks that you would like to find.
2. Set a minimum threshold to qualify as a peak.
3. Run the VI.
4. The results at the bottom will show you the X-axis locations of the peaks and their associated amplitudes.
Additional Information or References
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
