Example Code
Plot Digital Waveforms from Array Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This VI Plot Digital Waveforms from Numeric Array
Description
This VI construct one or more two dimensional Boolean arrays that represent the digital data. Each column in the arrays will represent a digital line, and each row will represent different samples. After the Boolean array are constructed, Digital Waveform VIs to build/plot the graph are used.
Requirements
LabVIEW 2012 (or compatible)
  1. Enter the Array elements
  2. Run the VI
Additional Information or References
VI Block Diagram
Plot Digital Waveforms from Array LV2012 NI Verified BD.jpg**This document has been updated to meet the current required format for the NI Code Exchange. **
Andy Chang
