Example Code
Plotting Comma Delimited Data from a string of comma separated values in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to parses a string of comma separated values and plots them on a Waveform Graph.
Description
This VI takes in a comma delimited string of data and breaks it apart using the Match Pattern.vi.  At this point the data is in the form of a string.  The String to Number.vi converts the data into the representation of a double.  This is performed inside of a while loop to build a 1-D array of doubles which can then be graphed.
Requirements
LabVIEW 2012 (or compatible)
  1. Configure a comma delimited String of values into the Input String input
  2. Run the VI
Additional Information or References
Justin Parker
Product Support Engineer
