Example Code
Plotting on a Waveform Chart Starting from a Relative Time of Zero Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to use two properties in a property node to plot a 1-D Array of Doubles to plot values starting from a relative time of 0 seconds.
Description
One chart appends values to the existing chart history every time the VI is run. The second chart clears the chart history so that it starts at time 0 every time the VI is run.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Specify the sample rate for the signal generation.
2. Run VI.
3. Execute same VI multiple times and observe differences between graphs
Additional Information or Resources
**This document has been updated to meet the current required format for the NI Code Exchange
