Example Code
Pole Placement for MIMO System in LabVIEW
Products and Environment
    Software
  • LabVIEW Control Design and Simulation Module
  • LabVIEW
Code and Documents
Description
 1. Overview
This example creates, analyzes and modifies a State-Space MIMO model using the Control Design and Simulation Module in LabVIEW.
2. Description
In control engineering, a state-space representation is a mathematical model of a physical system as a set of input, output and state variables related by first-order differential equations. "State space" refers to the Euclidean space in which the variables on the axes are the state variables. The state of the system can be represented as a vector within that space.
The CD Pole Placement VI Determines the Gain that places the closed-loop poles at desired locations in a system with full state feedback. You can use this VI with multiple-input multiple-output (MIMO) systems.
3. Requirements
  • NI LabVIEW Professional Development System 2012 or compatible.
  • NI Control Design and Simulation Module 2012 or compatible.
4. Steps to Implement or Execute Code
  1. Download and open the example VI.
  2. Write the Desired Pole Locations for the model. You can find the model's information in the block diagram.
  3. Run the VI.
5. Additional Information or References
  • Introduction to LabVIEW Control Design Toolkit 1.0 by Finn Haugen: http://www.techteach.no/publications/labview_control_design/
  • The CD Construct State-Space Model function has an input parameter called Sampling Time. When creating continuous-time models this input must be either unwired or wired with value zero. If a non-zero sampling time is connected, a discrete-time state-space model will be created (with the system matrices as defined by the 2-dimensional arrays A, B, C, and D).
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Andy Chang
