Example Code
Prime Number
Code and Documents
This VI find outs Prime Numbers in the range of given from and to numbers. Give numbers in From and To controls and Run VI. This will find prime numbers and display in an array.
Other requirements:
No hardware Require.
Comments
altenbach
Knight of NI Knight of NI
Knight of NI
on
Not very useful
- Your VI requires an OpenG tool, this should be noted in the "other requirements".
- Example code with a password protected diagram is useless. Please unlock.
BetaCommunityCo
Member
Member
on
req. code for LV 7.1
Can u pls send the code which will run on LabVIEW 7.1
Thnx in advance..
Sandeep
mail ID : sandeep.salunkhe@tatamotors.com
cirrusio
Active Participant
Active Participant
on
I'm going to go ahead and agree with altenbach here.  Why is it locked anyway?
PaulG.
Active Participant
Active Participant
on
Still locked. I guess top secret military secrets need to be locked up for quite a while.
PaulG.
Retired
Dcmm080294
Member
Member
on
Well I was trying to learn more about the programming
Contributors
