Example Code
Prime number Array of "n" elements
Code and Documents
Overview
This VI shows how to make an aray of prime numbers
Description
When you need to find the prime numbers between 2 to "n" , and get an array of prime numbers.
Hardware and Software Requirements
 LabVIEW 2012 (or compatible)
 select the max prime number you wish to make your array to and press RUN
Additional Information or References
Comments
PazhanivelVenkatt
Active Participant Active Participant
Active Participant
on
Will this work for Prime Numbers till 3 only.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Contributors
