Overview
This example is developed to populate the windows print dialog / printer seting window.
Description
This example is developed to populate the windows print dialog / printer seting window. And it is developed using .Net control.
Requirements
Additional Information or References
VI Snippet
Please click on like if you like it. ![]()
Your valuable suggestions are always welcome for the improvement.
Prabhakant
The windows opened is not modal, or not in front of all the others already opened.
It could be a problem
I want to combine your program with a file input, I set printer to be color but still print B/W.The other problem is the printer properties can't show up.
