Example Code
Print Labels or Reports in LabVIEW
Products and Environment
    Software
  • LabVIEW Report Generation Toolkit
  • LabVIEW
Code and Documents
Overview
This VI takes a string and pushes it to the printer using the report generation toolkit.
Description
You can use this simple SubVI whenever you wish to print a report or label. This VI will use the default printer for the computer, including networked printers. You can also specify a specific printer name on the print report vi.
Requirements
  • LabVIEW 2013 (or compatible).
  1. Enter a title and serial number into the corresponding controls.
  2. Run the program.
  3. The default printer will start printing the corresponding resultant strings.
Additional Information or References
Main VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange."
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
