Example Code
Print VI's Front Panel for LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
1. Overview
This example code prints the Front Panel of a VI.
2. Description
This example shows how to use the method "Panel to Printer" with a VI reference. It prints just the front panel to the current printer.
3. Requirements
  • NI LabVIEW Base Development System 2012 (or compatible).
4. Steps to Implement or Execute Code
  1. Download and open the example VI.
  2. Confirm that the default printer in File >Print Window is the one you require.
  3. On the front panel of this VI, use the control select VI/File to choose the VI of which you want to print the front panel.
  4. Run this VI.
  5. If you wish to save into a PDF instead of printing, select a device to do so in the printing preferences of your computer
    (Microsoft Print to PDF, Microsoft XPS Document Writer, CutePDF Writer, etc.)
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Kind Regards
Michael
NIUK Application Engineer
