Overview
A way to control the BIAS resistor settings programatically from LabVIEW using the Windows Registry VIs
Description:
This simple VI with using Windows Registry VI could show you how to change the settings of a bias resistor
Steps to implement or execute code
To implement this example:
- Decide whether to enable or disable bias
- Run the VI
- (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
- Install the required software.
- Connect the DAQ hardware of USB 485
- Confirm the connection with the MAX with TestPanel
- Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
USB 485
