Example Code
Programatically Change a Time Stamp Indicator Minute Hand to Chosen Values
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
To Demonstrate How to Manipulate the Timestamp Breakdown and Change the Value of it
Description:
This VI shows you how to change the time stamp minute hand by selecting one of a set of booleans and also allows you to output your data in a time stamp format.  This VI will take in the date and time and break the time out into hours, minutes, and seconds.  From there, we can manipulate each number and create a set of controls that will change the minute hand of the time stamp.  This VI can easily be modified to change another part of the time stamp.  In order for you to convert a portion of the time stamp, you have to bundle together all of the different factors that go into the time stamp (the time, the date, the year, etc.).
Instructions:
To implement this example:
  1. Run the VI
  2. Select the Boolean to manipulate the value
  3. Make adjustment as needed to change the value manipulation on the block diagram
To execute this example:
  1. Install the required software.
  2. Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
