Example Code
Programmatic Mouse Click Enable a Grayed Control in LabVIEW
Code and Documents
Overview
This code allows the user to "recover" a control that is disabled or grayed out.
Description
When a front panel control is disabled and grayed, it can be set to be enabled by clicking it. In this case, the user would still have to click the button again in order to bring up the menu to make their selection. By programatically initiating another mouse click, the same control can be enabled and then display the menu with a single click from the user.
Create a event structure that calls into the User32.dll to initiate a programmatic mouse click immediately after the first click.
Requirements
LabVIEW 2012 (or compatible)
  1. Run VI
  2. Click in the Ring Control
Additional Information or References
