Example Code
Programmatically Change IP Address of Real-Time Target in LabVIEW Project
Products and Environment
    Hardware
  • CompactRIO Controller
Code and Documents
Description
This example shows you how to work with a Real-Time (RT) target, where the target has an IP address that changes periodically, but you need to keep networking as is (cannot set IP to static). Since the IP address of the device changes periodically, you will need to change the IP address of the target within your project using the RT target Properties dialog box.
The example covers how you can change the IP Address Property of your RT target programmatically.
How to Use
You can access this property by editing the LabVIEW project's XML file. To change an XML tag, we can use the Set XML Tag method. The tag that we need to call out for IP address is alias.value.
See the attached project for an example of how to use the Set XML Tag method in this manner.
Contributors
