Description
Description-Separate-1This example covers a scenario where you have a project with a Real-Time (RT) target, and the target has an IP address that changes periodically, but you need to keep networking as is (cannot set IP to static). The example explains how you can change the IP Address Property of your RT Target programmatically.
Description-Separate-2How to Use
How-Separate-1We can access this property by editing the LabVIEW project's XML file. To change an XML tag, we can use the Set XML Tag method. The tag that we need to call out for IP address is alias.value.
See the attached project for an example of how to use the Set XML Tag method in this manner.
How-Separate-2
