Overview
The following is LabVIEW code that allows the user to change network settings of a National Instruments cDAQ 9188.
Description
The following is LabVIEW code that allows the user to change network settings of a National Instruments cDAQ 9188.This uses the System Configuration API found here:
https://www.ni.com/en-us/support/downloads/drivers/download.system-configuration.html
Requirements
Software
Hardware
Additional Information or References
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
Can you post a VB.net code for this?
