Overview
This VI has buttons that allow the user to programmatically switch from one tab to another.
Description
This demonstrates one way to programmatically change the tab on a Tab Control. The Tab is made an indicator, which means it does not directly take user input. Instead, it takes a value from a wire and changes based upon that.
An alternate method would be to make the tab a Control and then update the value programmatically with a property node.
Requirements
LabVIEW 2012 (or compatible)
Additional Images or References
Thanks for posting!
