Example Code
Programmatically Changing the Height of an Array Element Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code shows how to programmatically set the height of each element in an array.
Description
This code was developed where the height of the elements in a string array were needed to be fixed at a particular value.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the VI.
  2. Open the VI.
  3. Input values into the array
  4. Run the VI
Additional Information or References
VI Block Diagram
LabVIEW Product Marketing Engineer
