Example Code
Programmatically Changing the Visibility of Individual Tabs in a Tab Control
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This simple example shows how to programmatically change the visibility of specific tabs in a tab control.
Description
Sometimes it is useful to programmatically change the visibility of individual tabs in a tab control.  For example, you may only want the end user to have access to controls on a certain tab during parts of a test sequence.  When your code moves to a different part of your test sequence, then you might want to change the tabs available to the user.
This simple code demonstrates how you can use the "Page Visible" property to define the visibility of your individual tabs.
This VI was created in LabVIEW 2012.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open " Change Tab Control Visibility 2012 NIVerified.vi"
  2. Run the program
Additional Information or References
VI Block Diagram
Michael B.
Comments
Sasmar
Member
Member
on
Outstanding!
