Overview
Coding that exemplifies how to verify if a SubVI's input is not wired.
Description
You can programmatically check if an input terminal is wired to the SubVI by comparing the current value of the input to its default value. You will have to set the default value of the input to an improbable value. The Boolean (Is input value default?) can be used to control the behavior of the sub VI.
In the example below, we want to add two numbers together only if the x input is wired. If x is wired, it will compute x+y. If x is not wired, the VI will pass y through to the output. In this example, the x control has been assigned the number 999999 as default; and it is assumed that x will never hold that value.
Requirements
LabVIEW 2012 (or compatible)
1. Create a Blank VI.
2. Add the "Add If Input Wired LV12 - NI Verified.vi" to the block diagram and wire the terminals.
3. Specify a random value to the input X.
4. Disconnect this input and run the VI again.
Additional Information or References
Could someone please convert the vi to LV8.6.1???
